"Enable more frequent program guide refreshes" setting
Server Version#: 1.15.5.994
Player Version#: N/A
I noticed that in several places the documentation states that I should be able to allow more frequent updates of my guide data, however I’ve been unable to find this setting.
https://support.plex.tv/articles/225877347-live-tv-dvr/
Relevant portion:
When this option is enabled, program guide data will be refreshed four times daily, instead of only during the maintenance period. More frequent updates will increase the processing required by your server.
Is this a setting that is no longer available? I’m not seeing that in the DVR Settings modal. If so, should probably update the documentation.
Thanks for the heads up. We’ve removed the documentation. That setting was removed some time ago. Guide data now automatically does incremental update checks so that setting is no longer needed.
