EPG fails to update
@sa2000 : It seems to be working now ! Thanks a lot.
@sa2000 : working now here too. Thanks again for your efforts, much appreciated.
@sa2000 Thank you!
@sa2000 Thank you so much for your patient help with this issue. My program guide just downloaded perfectly and recordings seem to be going smoothly.
@sa2000 EPG is now updating again. Thanks for all your help! Very much appreciated!
all good here too! Thanks @sa2000
@chigy said:
Are there any news?
EPG updating is still failing:
    DEBUG - Activity: updated activity a80dbbf4-bbff-40c8-adda-3c079857ce5a - completed 22% - Refreshing EPG
    DEBUG - JSON parse error: Invalid value. (0)
    ERROR - EPG: JSON parse error. Data from request is <!DOCTYPE html>
     <p>The owner of this website (tmsapi.plex.tv) has banned you temporarily from accessing this website.</p>
Plex Media Server version 1.12.3.4947 has just been released as beta
It has a fix for caching bug where the cache was not correctly checked before making EPG requests to tmsapi.plex.tv. With this fix, the volume of requests should reduce significantly - 75% reduction has been observed. This should avoid getting Cloudflare rate limiting temporary IP Bans.
See Release Note http://forums.plex.tv/discussion/comment/1650553/#Comment_1650553
  • (DVR) HTTP request cache should properly check for file expiration when requesting celeb/series data. (#8405)
It still doesn’t work for me as soon as I disconnected VPN and refresh EPG. Attached is my log. Can you help?
Apr 10, 2018 17:06:26.458 [4412] ERROR - EPG: JSON parse error. Data from request is <!DOCTYPE html>
<title>Access denied | tmsapi.plex.tv used Cloudflare to restrict access</title>
You have timed this very well.
Just downloaded update…all is well here as well…it was a battle wasn’t it…
@sa2000. Thank you for your help and patience. EPG/Cloudflare issue seems to be resolved. EPG just updated normally. Still using Plex Media Server ver 1.11.3.4803. I will upgrade when 1.12.3 comes out of beta.
Would like to mention here an EPG related hot fix
The hot fix release for the bug giving rise to lost airings and recordings between 00:00 and 01:00 GMT on the day the EPG is refreshed is now available as beta release 1.12.3.4973-215c28d86
See Release Note
  • (DVR) Keep airings in US primetime from disappearing from the schedule on each refresh (#8448)
My guide is updating fully now. Still very slow, 2-3 hours each time for 10 channels.
On 1.12.2.4929, hopefully 1.12.3.4947 will get to the Shield soon.
Glad this issue was actively dealt with. There was a point a few years ago when WMC lost guide data for 3 weeks, no updates, no feedback. Not fun. The only saving grace was being able to set manual recordings .
Also having this issue with EPG. It will get up to 3%, but then just stall there for hours. I’ve rebooted, deleted the DVR and re-added, and also reduced channels to under the 300 it finds stock but it just does not work.
You need the latest beta release 1.12.3.4973
If problems persist would need server logs with debug logging enabled
Maybe an appropriate question I need an answer to before I consider to also have a very slow EPG download is, how long should it take to download the EPG on 290 channels at a download speed of 80mbps/Comcast USA?
Just upgraded from 1.11.3.4803 and it is even worst. Uninstalling and going back since the issue is still not fixed.
1.12.3.4973 is the best version for EPG refresh
The issue on this long forum thread was mostly relating to problems of timeouts in Ontario Canada which was resolved by Cloudflare
If you do have a problem on 1.12.3.4973 please raise a new forum topic and attach your server logs with debug logging enabled from the start (before launch) and logs captured after a refresh that fails or hangs
hi,
i’m in the version 1.13.1.5063, and when i click on ā€œguideā€ section , plex display the guide is empty, after guide refresh… same thing, another issue with the guide refreshing with this version ?
in plexpy after refresh i’m have this in plex server log
May 19, 2018 10:28:10.881	DEBUG	Activity: updated activity 03eb4b5c-e291-xxxx-8e15-0a32ebad4fe9 - completed 1% - Refreshing guide data
May 19, 2018 10:28:07.775	DEBUG	Completed: [192.168.2.7:58057] 200 POST /livetv/dvrs/10/reloadGuide (22 live) TLS GZIP 1ms 371 bytes (pipelined: 3)
May 19, 2018 10:28:07.774	DEBUG	Activity: registered new activity 03eb4b5c-e291-4d8a-8e15-0a32ebad4fe9 - Refreshing guide data
May 19, 2018 10:28:07.774	DEBUG	Activity: updated activity 03eb4b5c-e291-xxxx-8e15-0a32ebad4fe9 - completed 0% - Refreshing guide data
May 19, 2018 10:28:07.773	DEBUG	Request: [192.168.2.7:58057 (Subnet)] POST /livetv/dvrs/10/reloadGuide (22 live) TLS GZIP Signed-in Token (killpilot)
and nothing else… after 1%, he stop, strange…, before the processing time for refresh was long…
thanks for your help,
@killpilot said:
hi,
Please attach full logs zip and not just a snippet
See https://support.plex.tv/articles/200250417-plex-media-server-log-files/
Please wait 30 minutes before collecting logs if you see if not progressing
and please indicate if the Enhanced Program Guide option is enabled - that does slow down EPG refreshes considerably
