I live in Denmark - Zip code 4300 and got Stofa TV DVB-C
When I add my HDHomerun tuner and choose 4300 as zip code, I can´t see Stofa Cabel tv in the list.
I´ve tried to fit my channels with TDC - But I do not have EPG for all my channels.
Anyone got an advice?
I would recommend you to use EPG-DK. Fixes the problem for missing DK channels by using a custom XMLTV file. Has the full channel list from YouSee (234 channels).
@keithah said:
I have a ticket in already for Denmark to our metadata provdier, which I will check on, in the meantime you can go the custom XMLTV route.
Great, thanks for the info!
The zipcode limitation should be removed and all channels would be selectable … problem solved =)
