hi … when is the OTA EPG going to be available for winnipeg, mb, canada?
It should already be available. Gracenote fully supports Canada. However, Gracenote database is less than accurate about postal codes. First thing to do would be to try different postal codes within you OTA market. I live near Montreal and I got this issue where my postal code did not populate all channels. I was able to find a postal code that was working porperly.
Also, fill up the EPG issue form. It will takes several weeks, but plex/gracenote will fix your postal code. They fixed mine.
https://forums.plex.tv/discussion/281569/reporting-gracenote-epg-data-issues#latest
thanks … it was a matter of the postal not being read. I re-entered it slower and it worked,
