I have recently setup the PlexDVR and during the setup came out that just 2 first channels of my channel list (98 channels) have been matched against the Skylink EPG list. I had to rearrange the rest manually to assign the right EPG data, which is not a pleasant work as you can imagine, partly also because of the interface (small window an a lot of scrolling).
I know this is just one time procedure, but I am wondering why you don’t offer an option for a text based channel matching procedure.
There is one thing which would need a fix, I am not sure if on your side or on the side of the EPG provider.
There are two channels Ceskoslovensko HD and Festival HD but the EPG have them listed as one record.
Assigning the same EPG entry is blocked in the EPG setup.
Would it be possible to change the setup behavior to just warn about it but allow to save it?
There is one other channel which would benefit from this and this is Skylink Ochutnavka, which is a demo channel transmitting every month different channel for free. At this moment it is transmitting one of the Filmbox channels but in HD.
It turned out there is also 4 channels missing but this is no big issue for me.
Seznam.cz HD; C-music CZ; Mnam TV; TV regina
thanks for any comment
LH
