Episode Ordering Option Missing
Server Version#: 1.112.0.359-0d79a49f
Player Version#: 1.43.2.10687
I used to be able to set the episode ordering on my shows which was really handy for anime with specials or non-conventional ordering, but the option is gone for me. They didn’t remove the option did they?
In my experience, that usually means the show is incorrectly matched or not at all. Can’t help to much without knowing the show you are trying this on.
It’s Hidamari Sketch. Wanted to change it to DVD order because there’s 2 bonus episodes that I wanted included with the first season.
Hmm, I just added this to my testing library and it seems to have matched fine. When I click on Episode Ordering, I get the expected ordering options. Something odd is happening, there should be several more options to select or choose on the popup window.
Have you tried refreshing the metadata or doing a Plex Dance? I am wondering if you may have gotten an incomplete metadata pull.
And is this a particular season?
I just needed to fix the TV series match and the episode ordering setting reappeared.
