For many shows knowing the title of the episode is very important, not just seeing Episode 1. Shows like South Park that have no real season plot are dependent on episode title to know what it is.
How do I format my file names so that the actual name of the episode pops up (and is not just ignored).
For example, the show Firefly.
I want to watch an episode call “Out of Gas”, but I don’t know what episode # it is. When I look on my phone app, all I see is Episode 8 (with another smaller Episode 8 below it, or grey out on the web app - it displays the Episode 8 twice on both apps, as if it knows it is the eighth episode and it thinks the episode title is Episode 8.).
My file is:
Firefly - s01e08 - Out of Gas.mkv
Where do I put the episode title so that it shows as the Episode title in Plex?
See here - clearly there is a space for the real episode title, I assume the bold white (then the episode number in grey beneath).
Same issue for me for newly added episodes. Seems an issue with the TVDB agent.
I deleted cache.
I tried refreshing metadata.
I did the dance and now the whole TV show which had episode names before no longer does.
I removed all additional agents for Shows and TVDB leaving only TheTVDB.
This started around 2 weeks ago. The show is matched. I get the artwork for seasons and show description. I get all necessary information about the show on its main page. It is only the Episode Name that is not fetched.
If so, please check mediainfo and see what the Title field is. If there is a Title field and it’s null, then you need to remove it OR move LMA to the bottom. PMS keys on tags in MP4 files.
Also, I know that if I have file Details (from the Properties menu) defined, they do affect the naming. The files in questions have no details in the files. The episodes of other shows were recognized before. Doing the dance caused the episodes names to become unavailable.
Use FileBot or a similar renaming tool. I can give you the template (renaming rule) if you wish
If you are willing to give up the metadata, creating an ‘Other Videos’ type library, using the structure created by FileBot, it will appear the same as if PMS did it.
Is this what you’re trying to accomplish?
Edit: I would also like to help you resolve PMS ‘getting it wrong’. There is always a reason for these problems and the solution is usually pretty easy. I am willing to assist you with this as well if you’d prefer to have it ‘fully automatic’ with full metadata.
