Error Acquiring Certificate after Password Reset
@gazmeist
Your QNAP will do hardware transcoding and tone mapping of 4K UHD if you want it.
Docker brings the needed libraries with it
Here is the QNAP FAQ for it
Not sure my TS451D2 hs the required CPU for it - don’t currently have any 4K content anyway
Sadly even with the claim token and rebuild my server still doesn’t want to be seen for whatever reason. So frustrating, it was there (and not connecting) whenI first changed password, and when I tried troubleshooting myself at some point it just disappeared.
Pretty sure it was after I removed it from here - that ‘mystery’ new item now top left I think is the replacement that seems incomplete
The Log you showed me listed a J4025 CPU (dual core) with QSV hardware transcoding w/ tone mapping capability.
What’s your pleasure?
I really suggest you make the server network: host setting and not put the container in a different subnet (a major part of the problem)
I used to have that but gave me issues as I’m also communicating with other dockers for Transmission, Radarr, Medusa, and Jackett
Wait - actually I am using
#network_mode: host
That’s all fine.
On the NAS, unless you’re running two instances of the same program at the same time, what’s to be gained by abstracting the network?
To date, I’ve not found a reason.
Just noticed I’d #'d it out …
#network_mode: host
that’s commented out . it will put it in the 10.0.3.x / 10.0.5.x subnets
YEP… uncomment it
I appear to be having hte same problem as everyone else, reset password entered new claim ID cannot get to my plex server. Is someone able to reset this certificate step is that what needs to happen next?
thanks for all you help
@skam
Which of the 3 servers on your account please ?
Can someone please help me? I think my posts have been passed over given the amount of activity.
Thank you.
@ChuckPa “CloudPlex”
Now I remember why I had to do it…
Creating plex ...
ERROR: for plex  "host" network_mode is incompatible with port_bindings
Traceback (most recent call last):
  File "docker-compose", line 3, in <module>
    QPKG_NAME=container-station
  File "compose/cli/main.py", line 81, in main
  File "compose/cli/main.py", line 203, in perform_command
  File "compose/metrics/decorator.py", line 18, in wrapper
  File "compose/cli/main.py", line 1186, in up
  File "compose/cli/main.py", line 1182, in up
  File "compose/project.py", line 702, in up
  File "compose/parallel.py", line 108, in parallel_execute
  File "compose/parallel.py", line 206, in producer
  File "compose/project.py", line 688, in do
  File "compose/service.py", line 564, in execute_convergence_plan
  File "compose/service.py", line 480, in _execute_convergence_create
  File "compose/service.py", line 478, in <lambda>
  File "compose/service.py", line 457, in create_and_start
  File "compose/service.py", line 334, in create_container
  File "compose/service.py", line 941, in _get_container_create_options
  File "compose/service.py", line 1073, in _get_container_host_config
  File "docker/api/container.py", line 598, in create_host_config
  File "docker/types/containers.py", line 339, in __init__
docker.errors.InvalidArgument: "host" network_mode is incompatible with port_bin        dings
[29511] Failed to execute script docker-compose
Those are correct errors.
When in host mode, you don’t need port mapping.
they are all 1:1 automatic
So comment out all of this?
    ports:
        - 32400:32400
        - 32469:32469
        - 32401:32401
        - 32402:32402
        - 32403:32403
        - 3005:3005
        - 8324:8324
        - 32410:32410/udp
        - 32412:32412/udp
        - 32413:32413/udp
        - 32414:32414/udp
Holy mac and cheesballs… Finally getting the option to claim
Thanks for everything Chuck - that was painful I know. Have made notes of this all including that alternate tonemapping setup as well will explore it.
sorry for delay… was helping another user.
Yep, you got it.
  1. Was password reset required ? yes
  2. Has the password been changed ? yes
  3. Were all devices signed out (check the box when changing password) ? yes
  4. If all the above is complete, Please provide
    – Name of the server (friendly name) TheOutsiders123
    – Host OS it runs on (to confirm we have the correct server. windows10
cant find server please help!
sorry server is
WEIRS DRIVE-IN
