Error code: h4 (codec)
Hello,
Sorry if this is repetitive, but I get the Error code:h4 (codec) since the update. I saw others have the problem while trying to do certain things, but for me nothing works since the last update.
Please fix it
Hello, I did as you asked. Sorry but I cannot upload them here as I am a new user on forums. I attach a WeTransfer Link instead. https://we.tl/nHajqTglNz
Thank you
I have the same problem at my LG smart tv …webOS … how can I fix it?
Error vide: h4 (Code)
Sorry, error code: h4 (Codec)
I also have the same issue. movies that previously played no longer do with the same h4 error.
Same h4 (codec) error with all dvr content, including previous successfully played content. Same issue attempting to watch live tv via Plex sourced by HDHomeRun. HDHomerun app on its own works fine. I’m running Plex on a nVidia Shield Pro console.
I also now get error code h4 ;(
Do i need to switch to a different mediaplayerserver or will it be fixed?
Same issue here since last update. Kind of disappointed with how this is happening.
Same issue on LG Smart TV here!
Can someone at least post some kind of an update about this issue? It’s obviously widespread!
Update: Found a solution here
Basically, here’s what it says:
On the LG Plex TV app, go to “Settings → Main → Allow fallback to insecure connections on same network”, then restart Plex on the TV.
After this, my Server appears as “Nearby” instead of “Indirect” and the media files start up normally. And “Plex for LG” appears in the player list of the Plex IOS app.
