jwsii7
July 23, 2025, 11:30pm
1
Server Version#: 1.41.9.9961
I get the following error when adding a Managed Account to my plex server.
It does create the user but it doesn’t have access to the plex server.
When I try to give the user access I get the error.
This is a band new server install.
Thank you
Izzo_s
July 23, 2025, 11:59pm
2
Exact same thing was happening to me. Managed to create the users, but just a completely unhelpful “Unexpected Error” message when trying to set up the managed accounts. I even completely nuked my server and did an install from scratch just in case. No luck
I think your issue may be related to mine possibly, thanks to @Izzo_s for noticing.
Server Version#: 1.41.9.9961 on QNAP NAS
Player Version#: na
I’m trying to add library access to a managed account on the ‘plex home’ server screen. Every time I click ‘save changes’ button, it gives me this error. It doesn’t do this on my other pms servers, just this particular qnap pms server.
I checked the server log, and there are no errors or indicators a problem has occured. Only the UI message displays, with no other details. See screenshot. Can anyone advise please? Thanks
I als…
Hi all, the issue should be fixed now, could you try again and see if it works? Thanks!
Izzo_s
July 24, 2025, 1:49pm
6
Worked for me this morning. Thanks for the quick fix!
