Hi, getting the above error whenever I try to do any HW Transcoding. This has worked fine in the past on the same hardware. Nothing special or tweaked about the setup
Jan 27, 2024 12:05:50.650 [140379726445368] DEBUG - [Req#8f/Transcode] Streaming Resource: Determining preferred transcode encoders through transcode only decision.
Jan 27, 2024 12:05:50.650 [140379726445368] DEBUG - [Req#8f/Transcode] Codecs: testing h264_vaapi (encoder)
Jan 27, 2024 12:05:50.650 [140379726445368] DEBUG - [Req#8f/Transcode] Codecs: hardware transcoding: testing API vaapi for device '/dev/dri/renderD128' (Haswell-ULT Integrated Graphics Controller)
Jan 27, 2024 12:05:50.650 [140379726445368] ERROR - [Req#8f/Transcode] [FFMPEG] - No VA display found for device /dev/dri/renderD128.
Jan 27, 2024 12:05:50.650 [140379726445368] DEBUG - [Req#8f/Transcode] Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Invalid argument
Jan 27, 2024 12:05:50.650 [140379726445368] DEBUG - [Req#8f/Transcode] Could not create hardware context for h264_vaapi
Jan 27, 2024 12:05:50.651 [140379726445368] DEBUG - [Req#8f/Transcode] Codecs: testing h264 (decoder) with hwdevice vaapi
I see the other problem
Jan 27, 2024 12:05:13.576 [140379810421560] INFO - Plex Media Server v1.32.8.7639-fb6452ebf - Linux Mint PC x86_64 - build: linux-x86_64 debian - GMT 11:00
Jan 27, 2024 12:05:13.576 [140379810421560] INFO - Linux version: 21.2 (Victoria), language: en-US
We do not support Mint. It’s too unstable.
Manifestations like what you’re showing me here are why.
