They repeat every 30 seconds. The device 10.13.13.7 is a Netgear router ( R6400v2) that is setup to act as an access point. It is nowhere near the PMS (topologically speaking).
Does anyone know what’s happening here and how to fix it?
My setup:
PMS 1.16.3.1433-359b06978 on a Synology DS1019+
Go into the Netgear and turn off it’s advertizing itself as a network gateway. It may not be possible because you really are repurposing a gateway device. If it’s an AP, remove any “gateway” info. No routing information should be defined. Make it behave as the “media converter” it is.
I could not find any such settings. The netgear R6400v2 has a built in option to repurpose the router as an AP (which is what I am using).
With this option enabled though, most of the settings are greyed out and with the few that are left I cannot make any change to what you are suggesting.
But nevermind, I just simply set up a firewall on my Synology to block all traffic from that IP. The NAS and the AP don’t have any business communicating anyway
