Server Version#: 1.13.8.5395
Player Version#: 3.73.1
I have the following warning in the server logs, I would like to know where this is coming from and if this is normal ?
Best Regards
Oct 21, 2018 00:25:00.781 [0x7f81b0d11700] ERROR - Error issuing curl_easy_perform(handle): 7
Oct 21, 2018 00:25:00.781 [0x7f81b0d11700] WARN - HTTP error requesting GET http://192.168.168.1:56688/rootDesc.xml (0, No error) (Failed connect to 192.168.168.1:56688; No route to host)
Oct 21, 2018 00:25:07.797 [0x7f81b0d11700] ERROR - Error issuing curl_easy_perform(handle): 7
Oct 21, 2018 00:25:07.797 [0x7f81b0d11700] WARN - HTTP error requesting GET http://192.168.168.1:56688/rootDesc.xml (0, No error) (Failed connect to 192.168.168.1:56688; No route to host)
Oct 21, 2018 00:25:07.801 [0x7f81b0d11700] ERROR - Error issuing curl_easy_perform(handle): 7
Oct 21, 2018 00:25:07.802 [0x7f81b0d11700] WARN - HTTP error requesting GET http://192.168.168.1:56688/rootDesc.xml (0, No error) (Failed connect to 192.168.168.1:56688; No route to host)
Oct 21, 2018 00:25:10.813 [0x7f81b0d11700] ERROR - Error issuing curl_easy_perform(handle): 7
Oct 21, 2018 00:25:10.813 [0x7f81b0d11700] WARN - HTTP error requesting GET http://192.168.168.1:56688/rootDesc.xml (0, No error) (Failed connect to 192.168.168.1:56688; No route to host)
Oct 21, 2018 00:25:17.829 [0x7f81b0d11700] ERROR - Error issuing curl_easy_perform(handle): 7
Oct 21, 2018 00:25:17.829 [0x7f81b0d11700] WARN - HTTP error requesting GET http://192.168.168.1:56688/rootDesc.xml (0, No error) (Failed connect to 192.168.168.1:56688; No route to host)
Oct 21, 2018 00:25:17.833 [0x7f81b0d11700] ERROR - Error issuing curl_easy_perform(handle): 7
Oct 21, 2018 00:25:17.834 [0x7f81b0d11700] WARN - HTTP error requesting GET http://192.168.168.1:56688/rootDesc.xml (0, No error) (Failed connect to 192.168.168.1:56688; No route to host)
Oct 21, 2018 00:25:20.845 [0x7f81b0d11700] ERROR - Error issuing curl_easy_perform(handle): 7
Oct 21, 2018 00:25:20.845 [0x7f81b0d11700] WARN - HTTP error requesting GET http://192.168.168.1:56688/rootDesc.xml (0, No error) (Failed connect to 192.168.168.1:56688; No route to host)
Oct 21, 2018 00:25:27.861 [0x7f81b0d11700] ERROR - Error issuing curl_easy_perform(handle): 7
Oct 21, 2018 00:25:27.862 [0x7f81b0d11700] WARN - HTTP error requesting GET http://192.168.168.1:56688/rootDesc.xml (0, No error) (Failed connect to 192.168.168.1:56688; No route to host)
Oct 21, 2018 00:25:27.911 [0x7f81b0d11700] ERROR - Error issuing curl_easy_perform(handle): 56
Oct 21, 2018 00:25:27.911 [0x7f81b0d11700] WARN - HTTP error requesting GET http://192.168.0.250:8200/rootDesc.xml (0, No error) (Recv failure: Connection reset by peer)
Oct 21, 2018 00:25:43.900 [0x7f81b6fff700] INFO - AutoUpdate: no updates availablev
