hezten
June 22, 2013, 11:02pm
1
Im gettings thiis error trying to play content
01:02:33 XMLConverter: XML_ExpandLine - Error in {{MEDIAURL(Video)}}
Traceback (most recent call last):
File "/home/tonny/PlexConnect/XMLConverter.py", line 477, in XML_ExpandLine
res = eval("g_CommandCollection.ATTRIB_"+cmd+"(src, srcXML, '"+param+"')")
File "", line 1, in
File "/home/tonny/PlexConnect/XMLConverter.py", line 843, in ATTRIB_MEDIAURL
res = PlexAPI_getTranscodePath(self.options, res)
File "/home/tonny/PlexConnect/XMLConverter.py", line 510, in PlexAPI_getTranscodePath
vRes = quality[setQuality][0]
KeyError: '9'
i added some networks to preferences.xml to allow playback from my girlfriends ip, but that does not seem to work ?
- Tonny
hezten
June 22, 2013, 11:03pm
2
btw i can browse the movies and tv shows, but images are now showing (thumbnails)
f00b4r
June 22, 2013, 11:32pm
3
This is not a supported setup but if you search the forums you will find that someone resolved this issue.
You will continue to have issues if your girlfriend has a dynamic IP though as it will break again.
hezten
June 22, 2013, 11:35pm
4
any clues for what to search for ? tried "networks" and "preferences.xml"
f00b4r
June 22, 2013, 11:46pm
5
hezten
June 23, 2013, 12:03am
6
hmm disable gdm in settings does not prevent gdm lookup when i start the plexconnect. Also adding the correct network to plex does not get the streaming to work, i also tried proxying the trafic through apache, but as my settings are ignored ang gdm is used instead, this is not possible. How do i disable gdm so my settings for plex ip and port number is effective ?
baa
June 23, 2013, 6:43am
7
set "enable_plexgdm = False". not 'false' or whatever... what did you set it to?
hezten
June 23, 2013, 9:28am
8
i set it to False also tried false.. its still using gdm.
hezten
June 23, 2013, 9:30am
9
Look :-)
root@XBMCLive:/home/tonny/PlexConnect# grep "enable_plexgdm" Settings.cfg
root@XBMCLive:/home/tonny/PlexConnect# ./PlexConnect.py
11:32:02 PlexConnect: started: 11:32:02
11:32:02 PlexConnect: ***
11:32:02 PlexConnect: PlexConnect
11:32:02 PlexConnect: Press ENTER to shut down.
11:32:02 PlexConnect: IP_self: 194.255.31.57
11:32:02 DNSServer: started: 11:32:02
11:32:02 DNSServer: ***
11:32:02 DNSServer: Starting up.
11:32:02 DNSServer: intercept trailers.apple.com: 194.255.31.57
11:32:02 DNSServer: forward other to higher level DNS: 8.8.8.8
11:32:02 WebServer: started: 11:32:02
11:32:02 WebServer: ***
11:32:02 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
11:32:02 PlexGDM: ***
11:32:02 PlexGDM: looking up Plex Media Server
11:32:03 PlexGDM: servers discovered: 1
11:32:03 XMLConverter: PlexGDM - PMS: 194.255.31.57:32400
So even if it is set to false it looks up the server.
baa
June 23, 2013, 9:44am
10
Nice... you are right: You found a bug... you may keep it. :-D
Or grab the latest commit, it should be fixed now.
hezten
June 23, 2013, 11:32am
11
awesome.. i will test again soon as possible.. the apache mod_proxy should bix the issue and let plex think all connections are comming from localhost wuhuu
hezten
June 23, 2013, 11:48am
12
hmm oki i set up apache proxypass / http://194.255.31.255:32400 and let apache listen on port 8090 changed the pms port to 8090 in settings.cfg, now i get this
Error response
Error code 403.
Message: Not Serving Client 212.37.130.28.
Error code explanation: 403 = Request forbidden -- authorization will not help.
hezten
June 23, 2013, 11:58am
13
i would think the client should be 194.255.31.57 not 212.37.130.28 as the request is proxied though 194.255.31.57, does plexconnect send source ip in some way that can be altered ?
baa
June 23, 2013, 2:59pm
14
I dont think that is correct. There is no issue with PMS here.
What you have to do - as far as I understand:
- keep PMS on port 32400
- let Apache listen on port 80, forwarding the aTV to port 8090
- set PlexConnect to listen on port 8090 (port_webserver)
I don't think this is what you were doing, is it?
hezten
June 23, 2013, 3:12pm
16
ok so now plexconnect webserver is listening on port 8090 and i have setup this in apache
and apache is listening on port 80
plex is running with his
17:13:09 PlexConnect: started: 17:13:09
17:13:09 PlexConnect: ***
17:13:09 PlexConnect: PlexConnect
17:13:09 PlexConnect: Press ENTER to shut down.
17:13:09 PlexConnect: IP_self: 194.255.31.57
17:13:09 DNSServer: started: 17:13:09
17:13:09 DNSServer: ***
17:13:09 DNSServer: Starting up.
17:13:09 DNSServer: intercept trailers.apple.com: 194.255.31.57
17:13:09 DNSServer: forward other to higher level DNS: 8.8.8.8
17:13:09 WebServer: started: 17:13:09
17:13:09 WebServer: ***
17:13:09 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 8090.
17:13:09 XMLConverter: PlexGDM off - PMS from settings: 194.255.31.57:32400
17:13:36 DNSServer: DNS request received!
17:13:36 DNSServer: Source: ('195.215.209.204', 54072)
17:13:36 DNSServer: Domain: api-global.netflix.com
17:13:36 DNSServer: ***forward request
Service Temporarily Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Apache/2.2.22 (Ubuntu) Server at 194.255.31.57 Port 80
Error log says
root@XBMCLive:~# tail -f /var/log/apache2/error.log
[Sun Jun 23 17:13:04 2013] [error] proxy: HTTP: disabled connection for (194.255.31.57)
[Sun Jun 23 17:13:11 2013] [error] proxy: HTTP: disabled connection for (194.255.31.57)
[Sun Jun 23 17:13:13 2013] [error] proxy: HTTP: disabled connection for (194.255.31.57)
[Sun Jun 23 17:13:14 2013] [error] proxy: HTTP: disabled connection for (194.255.31.57)
[Sun Jun 23 17:13:22 2013] [error] proxy: HTTP: disabled connection for (194.255.31.57)
hezten
June 23, 2013, 3:15pm
17
changed the listening ip from 0.0.0.0 to 194.255.31.57 now the browser gives the same error again
Error response
Error code 403.
Message: Not Serving Client 194.255.31.57.
seems that my own client is now allowed.. pms runs on 194.255.31.57 that ip is listed in allowed networks.
f00b4r
18
You may want to wait for MyPlex support (you will only have to undo all of this when it arrives soon anyway).
f00b4r
June 23, 2013, 3:18pm
19
Or check out the Linux guide thread for Apache stuff
hezten
June 23, 2013, 3:22pm
20
even with 127.0.0.1 if fails
Error response
Error code 403.
Message: Not Serving Client 127.0.0.1.
so now plexconnect is running webserver on 127.0.0.1:8090 and apache is forwarding via proxy / to http://127.0.0.1:8090 and listening on port 80
how the heck do i allow localhost ? seems its forbiden i have set 127.0.0.1/255.255.255.0 in allowed network settings.
