Error starting - port 443: [Errno 13] - Centos 6 Minimal
Hi All,
I'm currently getting a "WebServer: Failed to connect to HTTPS on 127.0.0.1 port 443: [Errno 13] Permission denied" if 'enable_webserver_ssl=True' in Settings.cfg, that prevents PlexConnect starting.
I'm having trouble on a Minimal Centos 6.5 and Centos 6.6 servers.
PMS version is 0.9.11.4, PlexConnect version is 0.4-1.el6.noarch. Client will be ATV 3. The PMS has a static IP, and PlexConnect is being installed on the same machine as the PMS.
PMS works fine with the build via a broswer.
Note: I'm currently having this problem within VMWare Virtual Machines. The VM network has been setup with a bridged connection, so the VM's have their own IP on the network.
<span style="color:rgb(34,34,34);font-family:'Helvetica Neue', Arial, Verdana, sans-serif;font-size:14px;">I don't get an error if '</span><span style="color:rgb(34,34,34);font-family:Menlo;font-size:11px;">enable_webserver_ssl=False'</span><span style="color:rgb(34,34,34);font-family:'Helvetica Neue', Arial, Verdana, sans-serif;font-size:14px;">&nbsp;in Settings.cfg, in fact I can download the Certificate via Ethernet as documented </span><a data-ipb='nomediaparse' href='https://github.com/iBaa/PlexConnect/wiki/Install-Guide-Certificate-via-Ethernet'>here</a><span style="color:rgb(34,34,34);font-family:'Helvetica Neue', Arial, Verdana, sans-serif;font-size:14px;">.</span>
<span style="color:rgb(34,34,34);font-family:'Helvetica Neue', Arial, Verdana, sans-serif;font-size:14px;">Below is the PlexConnect.log</span>
[plex@pmsc66 ~]$ more PlexConnect.log
13:24:16 PlexConnect: started: 13:24:16
13:24:16 PlexConnect: Version: 0.5-dev
13:24:16 PlexConnect: Python: 2.7.8 (default, Jul  3 2014, 18:29:03)
[GCC 4.4.7 20120313 (Red Hat 4.4.7-4)]
13:24:16 PlexConnect: Host OS: linux2
13:24:16 PlexConnect: PILBackgrounds: Is PIL installed? False
13:24:16 Settings: getsetting enable_plexconnect_autodetect=False
13:24:16 Settings: getsetting ip_plexconnect=127.0.0.1
13:24:16 PlexConnect: IP_self (from settings): 127.0.0.1
13:24:16 Settings: getsetting hosttointercept=trailers.apple.com
13:24:16 ATVSettings: init class CATVSettings
13:24:16 ATVSettings: load settings
13:24:16 Settings: getsetting enable_dnsserver=False
13:24:16 WebServer: started: 13:24:16
13:24:16 Settings: getsetting port_webserver=8080
13:24:16 WebServer: ***
13:24:16 WebServer: WebServer: Serving HTTP on 127.0.0.1 port 8080.
13:24:16 Settings: getsetting enable_webserver_ssl=True
13:24:16 Settings: getsetting port_ssl=443
13:24:16 Settings: getsetting certfile=/etc/pki/plexconnect/trailers.pem
13:24:16 WebServer: Failed to connect to HTTPS on 127.0.0.1 port 443: [Errno 13] Permission denied
13:24:16 PlexConnect: WebServer_SSL not alive. Shutting down.
13:24:16 PlexConnect: Shutting down.
13:24:17 WebServer: Shutting down (HTTP).
13:24:17 ATVSettings: save settings
13:24:17 PlexConnect: shutdown
It appears that there is a permission error and that something else is running on 443. But I'm confused with what and how. The joy of trying this for the first time.
Results of 'lsof -i -P' :
[plex@pmsc66 ~]$ sudo service plexconnect stop
Stopping PlexConnect:                                      [FAILED]
[plex@pmsc66 ~]$ sudo service plexconnect status
python2.7 is stopped
[plex@pmsc66 ~]$ sudo lsof -i -P |grep :443
httpd   1164   root    6u  IPv6   9814      0t0  TCP *:443 (LISTEN)
httpd   1167 apache    6u  IPv6   9814      0t0  TCP *:443 (LISTEN)
httpd   1168 apache    6u  IPv6   9814      0t0  TCP *:443 (LISTEN)
httpd   1171 apache    6u  IPv6   9814      0t0  TCP *:443 (LISTEN)
httpd   1172 apache    6u  IPv6   9814      0t0  TCP *:443 (LISTEN)
httpd   1173 apache    6u  IPv6   9814      0t0  TCP *:443 (LISTEN)
httpd   1174 apache    6u  IPv6   9814      0t0  TCP *:443 (LISTEN)
httpd   1175 apache    6u  IPv6   9814      0t0  TCP *:443 (LISTEN)
httpd   1176 apache    6u  IPv6   9814      0t0  TCP *:443 (LISTEN)
[plex@pmsc66 ~]$
The certificates are available to the plex user, as I was able to download the profile using the Certificates via Ethernet.
My Plex Media Server install on minimal Centos is documented here (sorry it is very detailed):
I have followed the PlexConnect Redhat install guide here.
I have reproduced the problem on clean Centos 6.5 and 6.6 installs with the same problem.
While troubleshooting I disable iptables.
My Settings.cfg is:
[PlexConnect]
enable_plexgdm = True
ip_pms = 127.0.0.1
port_pms = 32400
enable_dnsserver = False
port_dnsserver = 53
ip_dnsmaster = 127.0.0.1
prevent_atv_update = False
enable_plexconnect_autodetect = False
ip_plexconnect = 127.0.0.1
hosttointercept = trailers.apple.com
port_webserver = 8080
enable_webserver_ssl = True
port_ssl = 443
certfile = /etc/pki/plexconnect/trailers.pem
loglevel = High
logpath = /var/log/plexconnect
My PlexConnect httpd plexconnect.conf file is:
NameVirtualHost *:80
NameVirtualHost *:443
<VirtualHost *:80>
ServerName trailers.apple.com
ServerAlias secure.marketwatch.com
ProxyRequests Off
ProxyPreserveHost On
BrowserMatch “^(iTunes-)?AppleTV” appletv
ErrorLog logs/plexconnect-error_log
CustomLog logs/plexconnect-access_log combined
<Proxy *>
    Order deny,allow
    Deny from all
    Allow from env=appletv
</Proxy>
ProxyPass / http://localhost:8080/ nocanon
ProxyPassReverse / http://localhost:8080/
<VirtualHost *:443>
ProxyRequests Off
SSLEngine on
SSLProxyEngine On
SSLProtocol all -SSLv2
SSLCertificateFile /etc/pki/plexconnect/trailers.cer
SSLCertificateKeyFile /etc/pki/plexconnect/trailers.key
<Proxy *>
    Order deny,allow
    Deny from all
</Proxy>
When I go to 'https://192.168.1.100' (example IP of my PMS), in a browser on another PC, I get a:
Forbidden
You don’t have permission to access / on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
I get the same error above when I try 'http://192.168.1.100'.
However if I go to 'http://192.168.1.100:443' I get the follow (expected error as it is a SSL port) that contains a reference to trailers.apple.com.
Bad Request
Your browser sent a request that this server could not understand.
Reason: You’re speaking plain HTTP to an SSL-enabled server port.
Instead use the HTTPS scheme to access this URL, please.
Hint: https://trailers.apple.com/
I'm just wondering if anyone knows what is not right? or what things can I  check.
Thanks in advance
You need to set enable_webserver_ssl=False, as Apache is doing the SSL translation for PlexConnect.  PlexConnect will listen on port 8080 so it can run as a normal user without superuser privileges.
As for the Forbidden message, that's expected.  The Apache virtual host config only allows browsers that match AppleTVs (for additional security).
ip_pms should be set to 192.168.1.100 in Settings.cfg
Thanks, that makes sense.
