root@omv:~# cat /proc/1/comm
systemd
root@omv:~#
I knew it was systemd, but I didn’t know /etc/default/plexmediaserver was for init and not systemd. I wonder what the complaints in the syslog re /etc/default/plexmediaserver were about if it’s irrelevant with systemd?
I think you’re confirming that my override.conf was the way to go. I’d like to know if it makes sense to you that the original problems I reported are a side effect of the /tmp problem in latest releases, and so overriding /tmp with TMPDIR= really is the right solution. At least for now. I didn’t report /tmp full originally because I wasn’t aware of it and only later put it together with my stated problems.
Gotta split now but will check in tomorrow. Thanks Chuck!
Oh! P.S.: Does updating Plex initialize override.conf? That would explain why I had to re-enter my override.
