I am not sure which change has resulted in this issue, but for a while I have been unable to sync new items to my iPad.
The iPad is a Mini generation 1, and my PMS is running in the linuxserver.io container on unRAID.
PMS v1.4.3.3433
Plex for iOS Beta build 9595 (although it has been a problem with previous builds.
Regardless of whether I trigger the sync from the web browser or from within the iOS client ALL episodes I set to sync show in the iOS app as failed to sync with a transcoder error.
I am not sure if this is a client or transcoder error so am posting it here as I am running the iOS beta app first.
I should note that I also have music sync’d to my iPhone which also runs the beta app and that appears to be ok.
The items I have set to sync have all been transcoded prior to being added to my plex library so I know they are good, and also play fine both transcoded and directPlay through PMP, Plex for Roku and PlexWeb.
I have attached server logs and app debug info in the hope they contain something useful. If any more information is required please ask.
Thank you
