Eşkıya (1996) incorrect metadata
Eşkıya (1966) and Eşkıya (1996) are two different movies.
But Plex DB only shows the 1966 one with wrong year. (https://watch.plex.tv/movie/the-bandit-1996)
TMBD has the correct movies 1996 and 1966
Can you fix it? Thanks.
Thank you for your report!
I have filed an issue.
Problem is solved, thank you for your support :slight_smile:
