Exact way to get PLEX on Apple TV 3
Hello. Im somewhat good with computers but clearly not on this little adventure. I was previously able to put plex on the ATV3 before the last update. Please all i need is an EXACT step by step guide on how to do it. I LOVE plex and love the effort people put in to make it work. Im also a proud plex pass member so i wanna take full advantage of the program if possible.
https://github.com/ibaa/plexconnect/wiki
Follow the installation guides.
Sorry to bring up an oldish thread, but is this still the case? I'm running Plex via Win 8.1 into a Roku but have just about talked my Dad (in England) into installing Plex on Win 7 and streaming to his ATV3. Problem is, I need the setup to be as foolproof as possible and I'm reading different things (like the latest update stops Plex Connect functionality, etc)
The WIKI is mostly accurate - it might miss some hints, though.
PMS->PlexConnect->aTV is still going strong. Or I just didn't hear otherwise. :-D
However, there is no guarantee Apple won't mess with it...
Just followed the instructions and it works well on my Mac Mini PLEX server and Apple TV!
Thanks for this!
so this works on the current apple tv? I am going to get a Apple TV tomorrow this chromecast is not working for me.
Yes this works fine on current ATV
Hello... I'm following these instructions except on the open ssl step.. it says Can't open Config file. Any suggestions on how to fix this?
Need more exact info, please open a new thread with the info requested in the "read before posting" sticky and we will get you up and running :)
Hi guys is it possible to have a tutorial for instaling Plex on my Apple TV ?
Thank you so much for your help ;)
Cheers
Cheers
You need to install:
  1. Plex Media Server (instructions here)
  2. PlexConnect (instructions here)
These two applications may run in the same, or in separate computers (PlexConnect may may run in a JB ATV2).
So brilliantly awesome! Got it to work in 10mins... I skipped the step of installing certificates on my Windows host but that was sorted out in a jiffy. Absolutely perfect guide. The best guide I've ever ever had the pleasure of following. Kudos to whoever wrote the guide & wrote the codes. Truly hats off.
Hello,
I have a problem with the sudo command.
it used to work, i was testing another tool some time ago and must done something wrong. I don't know any more what exactly.
This is the error i get on the command to run the plex connect.
sudo: effective uid is not 0, is sudo installed setuid root?
Does any one knows how 2 resolve my problem.
Hello,
I'm not a Mac person, but a quick google discovered this link. Maybe worth a look. http://serverfault.com/questions/316662/sudo-must-be-setuid-root-mac-os-x
I did those things with no result ,  i already googled allot on this issue.
Thats why i pose my question here. Maybe there is a workaround to launch the server.
it's not letting me open the Plexconnect.py, it asks me what would I like to open it with, any idea? running windows 8.1
Python is required:
https://www.python.org/download/releases/2.7.8/
If you read thru @meltman’s answer you could of found this on your own.
Hello,
it used to work, i was testing another tool some time ago and must done something wrong. I don’t know any more what exactly.
Run system recovery (hold command+r @ boot) or put in a osx boot disk or USB recovery thumb drive if possible then run disk utility and repair disk permissions. If this doesn’t fix it I would personally reinstall osx without any time machine or ccc recovery tools unless you wish to spend a lot of time debugging the issue, your choice.
Hi f00b4r, the four links from git-page “nix autostart”, showing how to autostart the plexconnect daemon in different flavors of linux, are not working anymore.
Fixed. Thanks for reporting.
