Is there a way to make episode names not show up in search?
What is the file in Plex that handles it? To make edition
I want to see only movie and tv show titles in search field
Thanks for fast reply.
Can I remove episodes names from main search?
It would be like the button “Movies/tv” the default option. Without need to open serach options and click movies/tv
You can exclude the entire tv-show library from showing up in your search results (via that library’s advanced options). But there’s no options to customize the default search result popup, except for the actual search preferences which control which sources will be considered in your search results, e.g. specific servers, online media sources).
