External media sharing is extremely slow
Server Version#: Version 4.66.1
Player Version#: 7.26
Hello there,
I’m using Plex for Years (Plex Pass Lifetime Member). Works perfectly. But now I tried to use the “remote access” function.
I have set up the shares (Port Forwarding) in the router and on the interface the share is also shown to me as working with the “check mark”. If I now access from another network (fast WLAN with 1 GB/sec downstream), the movies reload every 3 seconds. A smooth viewing is not possible. I have not entered a bandwidth restriction. My Synology Drive is with 50 MBit Upstream connected via Wire. In my Home WLAN everything is working perfectly.
Any Ideas what the problem can be?
When it comes to remote access, all that matters is the internet upload bandwidth you get from your ISP. Not sure if that’s the 50 Mbps you’re referring in your post (or if that’s only the local connection bandwidth of your Syno?).
Edit: how is the internet upload bandwidth comparing to your movie’s average bitrate?
In addition you can check the Now Playing dashboard in Plex Web to see how a video is being streamed. In case of a bad remote access setup, the connection can end up being indirect. This means the streams are routed through a Plex relay server because your client/server fail to establish a direct connection. Those indirect/relayed connections are limited to 1 Mbps (2 Mbps for Plex Pass members).
As for the dashboard… are those streams showing as Remote or Indirect?
Exemplary screenshot from the "now playing" section
Thanks for your reply. I will have a look for your points. Here what I can say for now.
The 50 Mbps it my internet upload bandwidth (it is a fibre connection, so this speed is realistic). I have the problem with nearly every video. even “small” mp4 or avi videos have this issue.
I will have a look to the dashboard when i’m at home. i’ve never seen this information on the dashboard before.
Remember, that as far as sharing content to external users, there are seven things that factor in:
1.) Your server performance
2.) Your network
3.) Your upload speeds
4.) The Internet
5.) The remote user’s download speeds
6.) The remote user’s network
7.) The remote user’s equipment receiving the stream.
You can control only the first three. Unfortunately, no one controls item 4, and your remote user controls 5-7.
I have one friend who gets 15MB/s bandwidth, which is what I have my streams capped (can only get 20MB/s upload with both my ISPs). My brother gets about 2MB/s because he refuses to add an additional access point for the location he has his TV or wire his TV for better performance. You cannot control their network and you can talk until you are blue in the face to have them change but, it is up to them.
As a network architect for a large company, here are my tips:
1.) Pay attention to your upload speeds. At your 50MB/s and having fiber, I would say you have done well, there.
2.) Make sure your network equipment has enough horsepower and a good infrastructure between your server and Internet connection. Personally, my server is a Synology NAS with two 1GB/s ports to the switch that also has two 1GB/s ports connected to my router. Those dual 1BG connections are port-channeled together. You don’t get a single 2GB/s link. You just get two 1GB links that distribute the load (and it can get really complicated how that is done). I also pay attention to my network switch and router performance. My router has the horsepower to provide up to 890MB/s of throughput. I also have built in Quality of Service into my network equipment. I am not requesting you suddenly become a network engineer. I am just saying you can go down a deep rabbit hole on settings to improve things on your end. However; it has been my experience, it probably isn’t your network as long as you were thoughtful in your setup and use good equipment.
Look at your server’s performance (CPU, Memory, Network, Disk IOps).
The rest, as far as what I would recommend, is have the remote user take a serious hard look at their home network.
And I ALWAYS prefer wired connections over wireless. My brother’s problem is that the access point is a floor beneath his TV and he has kids, so phones, tablets, work, personal PCs, etc. Wireless is a shared medium, so if you got 20 devices all connected up, you are going to have problems. I have 4 access points in my house, all with direct wires coming back to my network switch for their backbone instead of mesh. Not a fan of mesh.
Good luck. I am only hoping to maybe expand your scope of where to look. I do not wish to confuse you. People make a good living knowing the ins and outs of this stuff and it isn’t something someone can pick directly up in the course of a few days.
Thank you to both of you.
Here my findouts and a solution (I can’t explain).
  1. The movies were played “indirect”. So maybe that was a problem.
  2. After that I created the other “user” not as “Friend” as before but as “Plex Home User”. After that I could finally stream in a small test a movie without problems. Don’t know why, but in the Moment it works for me.
Thanks again for your support!
