Server Version#: 1.41.6.9685
Player Version#: iOS 2025.15.0
None of my external subtitles are showing up when I try to cast to my Chromecast. All my .srt files are completely ignored! This is my second most used feature, and now it’s completely useless.
This has been gone for over a month and still no fix. Can we have date for a fix? Or if will be fix at all?
This definitely wasn’t an issue before the “New Experience” update.
I’m having a similar issue with Android. Same server version #1.41.6.9685 on Xubuntu Chromium.
External SRT OpenSubtitles work pretty consistently when I cast from chromium on my PC. They work intermittently when I cast from my Galaxy Tab A, and they never work when I cast from my Galaxy S22.
Subtitles worked consistently with all those methods before the app update.
Same here. I Can see from Plex Dash that subtitles are converted into webvvt format unlike previous editions. It has worked for years and must be related to new version. Casting from windows browser all works. Please fix bug asap
I’ve had to move to jellyfin because all my apps updated. Sad. Sad terms.
Although jellyfin doesn’t support casting from the iOS app, and I’ve not figured out transcoding on there yet, Plex is a great option if only it worked.
