Extreme Latency with Collection & TV Recomendations
Server Version#: 1.42.2.10156
Player Version#: 2025.24.0 (1235)
Curious if anyone has any ideas here, I recently migrated my Plex docker to Unraid with a library of ~1k of movies and ~8.5k tv episodes (15.8tb total). After enabling video thumbnail previews my config folder obviously ballooned to over 120gb; this didn’t surprise me but afterwards opening TV show recommendation page or movie collections takes upwards of 45seconds…
Any ideas? I’m already running the config/library folder on a sata ssd cache disk (4tb crucial), vacuumed the SQLite library, rebuilt indexes, optimized, increased cache in the UI and DB, analyzed the library as a whole and added a gpu passthrough.
I really like the professional feel of the thumbnails but I am starting to get frustrated with the latency/loading issues. Opening the logs briefly it looked like it’s just slow DB responses. Open to suggestions! Hardware is: Dell R720 with 2 Intel® Xeon® CPU E5-2690 v2 @ 3.00GHz, 128gb of RAM, 26tb Unraid pool (with parity), 4tb Crucial SSD cache disk and an NVIDA Tesla P4 GPU for transcoding.
Plex Media Server.log (30.1 KB)
One suggestion from reddit was to disable some of the suggestions for recommendations; this worked to resolve the recommendations tab! The recommendation of more from (network) was the cause there.
Still having issues with collections though… I removed all smart collections, here is updated logs.
Looks like there might be some old data as I have had the library for over 5yrs, any suggestions on cleanup? The warning on how long it took to retrieve items seems to be every time I open a collection…
Plex Media Server-2.log (53.3 KB)
Unraid is not in the list of supported hosts, though. It may be outside his office hours, but I’ll try to ask.
@ChuckPA curious if Unraid is supported in DBRepair somehow?
Ah sweet! Looks like dockerized instances are supported; I’ll install, run it and report back soon!
DBRepair does support specific images :slight_smile:
  1. Plexinc-PMSdocker
  2. BinHex
  3. HotIO
to name a few
You must run it from the “console” INSIDE the container.
(the pathnames inside a container are always the same)
