Failure to retrieve Danish ZIP codes in DVR Configuration
After a normal local network problem, I had to rescan my HDHomerun for channels. After this PLEX failed to load the channels. I dropped the DVR to reinstall.
However the reinstall fails. When I get to the second page and chose my language to “DANSK”, I then enter my ZIP code, and PLEX goes looking for 30 seconds, and the returns to the ZIP field without any errors, but the “CONTINUE” button is shaded and don’t work.
Consequently I cannot install a DVR any longer :frowning:
Tim
Synology DSM Version: 6.2.2-24922-2
Problem found. Plex was behind version. Forgot it does not autoupdate :blush:
