When running Plex on an XBOX One (home) with a number of local accounts for your family members, ie your kids there is a problem in using the same Plex login between all Plex sessions. Through plex one has the ability to add local accounts which do not require a Plex login, but work locally with defined restrictions. This is great to cut up your content and allow some users to see things others cant.
The issue I have is that if I login to my Gamer profile on the XBOX One and run the Plex app, it requires a PIN. This is normal and resolved very quickly. Once I have logged in, I can select my own user or a family members profile to start watching content. Now if say a family member logs in to their XBOX One profile, and then runs Plex, it will ask them to enter a PIN. Since I have already done this under my primary profile, and since I am the owner of the Plex account with my linked family accounts I need to re-authenticate. This is fine if its only required for the first time, but if I go back to my XBOX One Profile, and then re-run Plex, I have to again type in a PIN. This happens back and forth each time the opposite user wants to use the Plex App…
Help!
