Player Version#: 4.19.2 (Tizen 5.0)
Would be very nice to have an option to crop letterbox movies to 16:9 so that they fill the screen, since the tvs zoom option is disabled while the Plex app is active.
(a) you’re posting in the wrong section for feature suggestions… those should go here instead:
https://forums.plex.tv/c/general/feature-suggestions/
(b) there already exists a feature suggestion for that:
If it’s ok for you… let’s close this one to avoid further “distraction” ![]()
Is the codebase the same for all smart tv clients? The other requests targets roku and androids.
If it is the same, then sure. This should be closed. If it is separate codebase, then maybe this should be moved to he other section?
