[Feature Request] Map view for Photographs
Hi
Is it possible to add a map view for photographs where they have GPS metadata.
In Plex Web, at least, geotagged photos will show a map when you open the Information panel. Clicking on the map will open a new tab to Google Maps, centered on the location. There is currently a known bug, though, as this is not working for .dng files. It works well for .jpg files.
Not sure if this is possible or practical with a device like Apple TV or Roku. I haven’t seen a good map app.
Hi - Thanks for response
I was thinking more of showing the number of photos you have on a map with thumbnails - which then enables a filtered view based on photos by location
. The screenshot is from QuMagie (Qnap) that illustrates what I mean. You can then click on a location and it shows the photos that you have for that location
