Feature request-Move folders
I keep different folders for different movies. One of my main folders I use is New movies and watched movies. I have so many movies, rather than looking at the flags I like to only see unwatched without having to change the filter. After I watch them, they are moved to the watched folder. Its just the wife and I as I keep the kids movies in their own folders. I would like to see if an option to move the movie file directly in plex, kind of like the delete option. Since all of these folders are already identified as a source in the plex server, then a drop down should be achievable. This is kinda of an OCD request…
There are two similar existing requests. Do either take care of your requirements?
Unless I missed something, this doesn’t fully match what I was requesting. While I can move these files manually using file explorer, I would like to be able to do from plex remote myself. Im looking for an option to use remote, say on apple tv and move it to another already created Library. I can do similar file explorer like tasks, including delete files or match duplicates and delete. So a move would be a great option.
I think this one might be a full match with what you’re looking for.
