Feature Request - Plex Remote
I love the plex mobile app but it would be great for it to have a type of 'remote' so that browsing is as easy as possible. If you could browse the catalogue and set it to play on the server instead of the device that would be amazing!
I'm slightly confused, as far as I understand this is the case?
I looked up some random pictures as found via Google while I hope you can elaborate:
So what am I missing, is it the interpretation of the word easy perhaps?
Well, if you install a Plex client like Plex Home Theatre (Plex/HT) on your server, then yes it is possible to use Plex/Web, Plex/iOS and Plex/Android to browse the catalogue and issue play commands from it to Plex/HT. I do this every day.
Unless I am completely missing the point, I'd like to see this thread closed.
