[FEATURE REQUEST] Tuner Pooling during DVR setup
  1. I would like to be able to add two tuners that are the same as a pooled device then setup the channels.
  2. Currently when you add multiple tuners you have to do the channel scans and channel selection as two separate tasks.
  3. If possible I would like to have an option to [Setup up multiple tuners]
  4. Add both tuners
  5. Set up program guide
  6. Scan channels
  7. Select transcoding level (if available on the tuners)
  8. Select and deselect the channels that I want (HSN and QVC have got to go as an example)
  9. Later be able to edit the pooled tuner channel line up to add or remove stations
  10. Later be able to add another tuner to the pool.
  11. Later be able to add a tuner and create a pool off the single tuner that was set up using the settings that were already on the first tuner.
  12. Also have an option to not create a pool for those who like how it works currently.
This would ease setup a lot. I am getting old and my brain is slowing down.
Thanks for your consideration
-Casey
I have two tuners (HD HomeRun Primes)… i too am old with a slowing brain…
The joy of firing up the HD HomeRun setup Software, and copy / pasting the hundreds of channels into Excel… and then cross referencing what my cable company says I’m getting… Sorting the spreadsheet… annotating what channels need to go…(Non English Channels, SD channels that have an HD equivalent, Local Access Channels, etc…, then double clicking to put a Red X next to each channel I don’t want Plex to see (or any other app for that matter). I sure wish there was an easier way…
It would be nice if Plex could see my two HDHomeRun Primes / Six Tuners as one device for setting up Plex.
SJ
