Files being put into "Temp"
Server Version#: 1.25.2.5319
Player Version#: various
All of a sudden, new TV shows that I put on my WD device are all ending up in a show “Temp”. Under Temp are Season 1, Season 2 etc. The naming convention I’m using has not changed “Show Name S01E05” and it has worked great in the past. I had it rebuild the database but it didn’t change anything.
