Server Version#: 1.20.1.3252
I’ve just upgraded to the above version and resolved the issue whereby the Plex user account no longer has admin rights preventing access to all content
However, whilst I can now play any files located within Plex, other devices on the network (Naim muso & Cambridge Audio streamer) that used to be able to find & play these files can no longer see any files/the uPNP source that worked before the upgrade
I initially granted the Plex account Read then Read/Write to try to get the files visible and have restarted the NAS to ensure these changes are applied - no joy
So I now can’t play any music or videos
Any ideas as to what I need to change?
Did you place the media files inside the Plex share?
I don’t know that equipment but I would assume it uses DLNA to connect to the Plex Media Server. I believe that newer versions of Plex Media Server default DLNA to off. Go into the server settings and make sure it’s turned on.
Don’t know if that’s it but it’s why I’d try.
Nope, they were and still are outside it
Thank you so much!
That was it, enabled DLNA and everything’s working fine
It sounds fortunate that I don’t have an LG TV, but thank you
