For some reason, Plex is not indexing The Fourth Estate. Do I have the name wrong?
Settings:
Current naming:
The Fourth Estate s01e01.mkv
The Fourth Estate s01e04.mkv
Agents:
Movies - Personal Media: Local, Plex Movie, Chine
Movies - Plex Movie: Local, Plex Movie, Cine
Movies - The Movie db: Local, The Movie db, Plex
Shows - Personal Media Shows: Personal, Local
Shows - The TVDB: Local, The TVDB, Plex, The Movie db
Shows - The Movie db: The Movie db, Local, TheTVDB
Look it up on TheTVDB. The name is correct:
https://www.thetvdb.com/series/the-fourth-estate
The file name is only half the success when it comes to tv shows.
Equally important is the folder structure where the files are situated.
How does this look like on your server?
https://support.plex.tv/articles/200220687-naming-series-season-based-tv-shows/
If this was added initially with different file names, you need to clean out the mismatch from the Plex database by performing the Plex Dance
Updating the Library Scanner and Agent appears to have fixed the issue.
Thank you for the info you provided!
I’m not sure what you mean by that.
