Hi I recently have the same issue. I had already given Plex permissions to my video folders but it is still showing as unavailable. When I try to remove folders and re add I get errors that my changes cannot be saved. I am at a loss what to do next. I have two media folders and one of them is working while the other is not.
I have multiple folders and one of them the precreated videos folder still work but the other (downloads) does not. I have changed permissions many times and still doesnât quite work.
Can you show me (screenshot) the Permissions tab for one of your media shares ?
Then, please use File Station
go to the share (left pane)
right-click the share -> Properties
Show me what the ownership / permissions are there. I suspect this is where the root problem is.
In your Forum profile / settings, you can enable notifications & âsubscribeâ to threads you reply to. This is how I receive email notifications. It saves a ton of time as well as providing a direct link.
Second:
I will assume (?) the mandatory restart of DSM has been performed.
I have seen cases where DSMâs internal database becomes argumentative. It seems this is the case here. We can resolve it âfairlyâ easily
Stop Plex
Rename the bad share to something different (control panel - shared folders)
Create a new share to replace it using the previous proper name on the same volume
a. Be certain to assign username permissions. including Plex
b. Assign any NFS/SMB share access privileges
Using FileStation,
a. Open the âoldâ share
b. Highlight all items contained therein
c. Right-click and Move To -> back where the media belongs
d. â Optional: If youâre familiar with the shell, you could sign in at the shell at this point and perform a linux-level mv command on it for instant move (truly is instant)
Thank you!!! I was having an issue where every folder was readable except my Video folder. Creating a new one and moving files over did the trick! Plex was able to find everything right after I made the change. Thanks again!
