Hi
Is there anyway/anywhere that I can check for the correct episode sequence for a season of a particular TV show.
I used to be able to check The Movie Database (TMDB), but I understand that Plex now uses its own database.
Plex still uses themoviedb.org as the fault, but they’ve also added the ability to match the order with thetvdb. There’s a setting you can change after matching.
You can check Plex’s db by going to:
Search in the upper left hand corner for the show/movie.
Good luck!
Chris
Thanks - I’ll check it out
Thanks Chris - I’ll check it out
Plex does have their own database. HOWEVER, Plex doesn’t really use that as the numbering for shows. By default, all TV libraries use TMDB, but you can change episode ordering to TVDB if you desire. You can change the numbering source on the entire library at once, and over-ride the numbering per show as well.
OK - thanks
