Filter unlabeled movies
I use labels for parental control, which works great, but it’s becoming a bit of a maintenance headache. I’m not able to easily tell if I’ve missed a movie to label/tag as kids. When in a library, I can filter for everything with a certain label, but I can’t see what all doesn’t have a label so that I can add one if needed. The custom filter doesn’t allow label as one of the fields it searches against.
I need to either be able to use label in the custom filter, or the label filter needs to have an option.
As a workaround, you could use ExportTools
Interesting idea. Thank you.
