Can you allow multi-select to any options, like GENRE. You should be able to filter by DOES NOT CONTAIN ‘XYZ’
Also, is it possible to add the ability to use AND, OR when creating filters, for example:
ArtistRating is EMPTY OR
ArtistRating is GREATER THAN '3' OR
AlbumRating is GREATER THAN '3'
