Fire Stick stops playing live tv every few minutes, exits to guide. ([FFmpeg] [ERROR] [tls @ 0x81b7e740] Error in the pull function.)
Yes it should the issues mentioned with rewinding after starting playback, as well as looping midstream and endless buffering. The 90 minute drop out issue should also be resolved if it’s looping at the 90 minute mark / when the server starts pruning the segments (this might have another issue in the server side).
Builds for Live TV can be found below, the new playback stack in this build has only been enabled for Live TV playback and won’t impact normal playback from Plex Media Server or Plex content.
Fire TV / SHIELD Tube / Armv7a
https://artifacts.plex.tv/android-experimental/8.15.0.23515-d988edae/PlexForAndroid-8.15.0.23515-d988edae-Armv7aAmazonFireExo.apk
SHIELD Pro / Armv8a
https://artifacts.plex.tv/android-experimental/8.15.0.23515-d988edae/PlexForAndroid-8.15.0.23515-d988edae-Arm64v8aGooglePlayStdExo.apk
If you have any issues please let me know and include the client logs if you can, will follow up on them.
I will test it out right now and get back to you in a few hours.
300 second bug: Using the Firestick 4k with Hauppauge WinTV-quadHD, 1080i content and transcode interlaced turned ON while playing at original quality I can confirm the above fix has played for longer than 300 seconds.
It seems to load channels a little faster. Could be just my imagination.
90 minute bug: Using the Firestick 4k with xTeVe playing progressive content on original quality the above fix has played longer than 90 minutes.
App version: 8.15.0.23515 (821411256)
Fire Stick 4k 3-11-21.txt (773.5 KB)
I can confirm it plays beyond 300 seconds. So that bug appears to be squashed.
  • There appears to be a new bug where I can’t fast forward to live after rewinding.
  • Also, I still have the bug where I can’t switch from one channel to the next. It crashes back to the guide and I need to tune to the channel again to get it to play. This happens every time.
  • The new logging appears to be missing items also. It doesn’t show the 0000##.ts file it opening. That part was helpful I think. Can you add it back?
Here is a snip from the seeking issue I’m seeing
03-11 12:25:49.866  i: [FFmpegExtractor] IO-seek has been requested, target of 0 bytes (whence 65536).
03-11 12:25:49.867  i: [FFmpeg] [INFO]     Stream #0:1
03-11 12:25:49.869  i: [FFmpeg] [INFO] [0x101]
03-11 12:25:49.871  i: [FFmpegExtractor] IO-seek not resolvable, returning -38 instead.
03-11 12:25:49.884  i: [FFmpeg] [INFO] [FFmpegExtractor] IO seek completed to -38 Interrupted: No Closed: No
03-11 12:25:49.888  i: [FFmpeg] [INFO] [FFmpegExtractor] Requesting IO seek to -1 bytes.
03-11 12:25:49.891  i: [FFmpegExtractor] IO-seek has been requested, target of -1 bytes (whence 2).
03-11 12:25:49.906  i: [FFmpegExtractor] IO-seek not resolvable, returning -38 instead.
03-11 12:25:49.907  i: [FFmpeg] [INFO] [FFmpegExtractor] IO seek completed to -38 Interrupted: No Closed: No
03-11 12:25:49.908  w: [FF] AVC configuration parser failed, falling back to using the original initialisation data.
03-11 12:25:49.909  i: [VideoUtils] MediaCodec found (OMX.MTK.VIDEO.DECODER.DVHE.STN) for video/dolby-vision
03-11 12:25:49.910  i: [VideoStream] Dolby Vision is unsupported on this display or device.
03-11 12:25:49.911  i: [ExoPlayer][EventLogger] videoInputFormat [eventTime=454.29, mediaPos=289.52, window=0, period=0, id=0, mimeType=video/avc, bitrate=20505000, codecs=h264, res=1920x1080, fps=29.97003]
Looping issue and/or crashing to guide after 300s is fixed in this build on shield64. Yay!
Can’t speak to any other usability issues with build as we are currently using ESPN app for basketball. Will report back if any other issues tonight when we are switching between channels.
Thanks @sixones and @jg121212 for sticking with it and staying on top of it.
I’m not seeing any crash in your logs, did it display an error when you changed channel? Would you be able to replicate the issue again, wait a few minutes before switching channels and note the time you switched, if you can reshare the logs I can take a look.
Will see if I can replicate the rewinding and fast forwarding back to the live position issue.
@sixones @jg121212 I have tested the fast forward to live after rewinding at different playback positions and do not encounter any crashes or errors.
Fire Stick 4k Logs 3-11-21 a.txt (1.3 MB)
Looking at the logs, it appears that when switching channels, the player is not resetting the event time and media position back to 0. It is trying to play channel 7.1 using the event time and media position that were left over from channel 6.1.
Tuned to 6.1 for a couple of minutes
03-11 14:32:05.982  i: [LiveTuningBehaviour] About to tune channel: (6.1)
Switched to 7.1, received Popup - Error: Recording failed. Please check your tuner or antenna.
03-11 14:36:01.130  i: [LiveTuningBehaviour] About to tune channel: (7.1)
03-11 14:36:01.131  i: Fetching [method:POST] https://192.168.1.140:32400/livetv/dvrs/15/channels/7.1/tune?X-Plex-Token=...gYad
03-11 14:36:01.133  i: [LiveLocalSeekBehaviour] The current item changed, resetting known SeekWindow.
03-11 14:36:01.134  i: [Player][DimensionsLayout] Resizing: 1920 x 1080
03-11 14:36:01.135  i: [MediaSessionBehaviour] Updating metadata for video, thumb: false
03-11 14:36:01.140  i: [LiveAiringMediaItemsMonitor] Cancelling change detection
03-11 14:36:01.143  i: [LiveAiringMediaItemsMonitor]. Will signal items changed in 1499000 milliseconds
03-11 14:36:01.147  i: [PlaybackTimeBehaviour] Time: 228496 IsStarted: true
03-11 14:36:01.163  i: [RecordingSchedule] Fetching schedule because an item has finished recording.
03-11 14:36:01.168  i: Fetching [method:GET] https://192.168.1.140:32400/media/subscriptions?X-Plex-Token=...gYad
03-11 14:36:01.176  i: Fetching [method:GET] https://192.168.1.140:32400/media/subscriptions/scheduled?X-Plex-Token=...gYad
03-11 14:36:01.186  i: [ExoPlayer][EventLogger] surfaceSize [eventTime=235.27, mediaPos=228.29, window=0, period=0, 1920, 1080]
03-11 14:36:01.190  i: [PreplayViewModel] Refreshing metadata for Season 1950
03-11 14:36:01.191  i: [RecordingSchedule] Fetching schedule because server activity received.
03-11 14:36:01.194  i: Fetching [method:GET] https://192.168.1.140:32400/media/subscriptions?X-Plex-Token=...gYad
03-11 14:36:01.217  i: Fetching [method:GET] https://192.168.1.140:32400/media/subscriptions/scheduled?X-Plex-Token=...gYad
03-11 14:36:01.221  i: [Player] onDisplaySizeChanged(1920x1080 at 0x0)
03-11 14:36:01.222  i: [ExoPlayer][EventLogger] videoSize [eventTime=235.31, mediaPos=228.31, window=0, period=0, 1920, 1080]
03-11 14:36:01.226  i: [ExoPlayer][EventLogger] renderedFirstFrame [eventTime=235.31, mediaPos=228.31, window=0, period=0, Surface(name=null)/@0x715f7d1]
03-11 14:36:01.230  i: [EngineEventManager] Item change detected (Ad break: false)
03-11 14:36:01.232  i: [EngineEventManager] onPlaybackStopped: Skipped
03-11 14:36:01.235  i: [PlaybackTimeBehaviour] Playback stopped, pausing stopwatch
03-11 14:36:01.237  i: [VideoAwakeBehaviour] Keep screen awake has been requested disabled for VideoAwakeBehaviour.
03-11 14:36:01.247  i: [VideoAwakeBehaviour] Disabling screen on
03-11 14:36:01.248  i: [PlaybackTimeBehaviour] Time: 228571 IsStarted: false
03-11 14:36:01.250  i: [TranscodeSessionBehaviour] Channel has not changed, not stopping transcode session.
03-11 14:36:01.251  i: [PlayQueueProgressBehaviour] Updating PlayQueueManager state, isPlaying: false
03-11 14:36:01.268  i: [WiFiLockBehaviour] Releasing WiFi lock since playback was stopped.
03-11 14:36:01.282  i: [LiveTimelineBehaviour] onPlaybackStopped: Channel has not changed, not sending timeline event for Skipped
03-11 14:36:01.284  i: [PlaybackTimeBehaviour] Time: 228571 IsStarted: false
03-11 14:36:01.286  i: [EngineEventManager] onBufferingStarted (isSeeking: false)
03-11 14:36:01.288  i: [TranscodeSession] Pausing...
03-11 14:36:01.289  i: [ExoPlayer][EventLogger] playWhenReady [eventTime=235.35, mediaPos=228.31, window=0, period=0, false, USER_REQUEST]
03-11 14:36:01.290  i: [ExoPlayer][EventLogger] isPlaying [eventTime=235.35, mediaPos=228.31, window=0, period=0, false]
03-11 14:36:01.292  i: [EngineEventManager] onBufferingEnded
03-11 14:36:01.293  i: [Player] onDisplaySizeChanged(1920x1080 at 0x0)
03-11 14:36:01.295  i: [ExoPlayer][EventLogger] videoSize [eventTime=235.39, mediaPos=228.31, window=0, period=0, 1920, 1080]
03-11 14:36:01.299  i: [ExoPlayer][EventLogger] renderedFirstFrame [eventTime=235.39, mediaPos=228.31, window=0, period=0, Surface(name=null)/@0x715f7d1]
03-11 14:36:01.300  i: [Player][DimensionsLayout] Resizing: 1920 x 1080
03-11 14:36:01.306  i: [Player][DimensionsLayout] Resizing: 1920 x 1080
03-11 14:36:01.313  i: [PreplayViewModel] Refreshing metadata for Season 1950
03-11 14:36:01.317  i: Fetching [method:GET] https://192.168.1.140:32400/library/metadata/114745?includeExtras=1&includeOnDeck=1&X-Plex-Token=...gYad
03-11 14:36:01.327  i: [RecordingSchedule] Fetching schedule because server activity received.
03-11 14:36:01.328  i: Fetching [method:GET] https://192.168.1.140:32400/media/subscriptions/scheduled?X-Plex-Token=...gYad
03-11 14:36:01.330  i: Fetching [method:GET] https://192.168.1.140:32400/media/subscriptions?X-Plex-Token=...gYad
03-11 14:36:01.332  i: [PreplayViewModel] Refreshing metadata for Season 1950
03-11 14:36:01.333  i: Fetching [method:GET] https://192.168.1.140:32400/library/metadata/114745?includeExtras=1&includeOnDeck=1&X-Plex-Token=...gYad
03-11 14:36:01.334  i: [RecordingSchedule] Fetching schedule because server activity received.
03-11 14:36:01.335  i: Fetching [method:GET] https://192.168.1.140:32400/library/metadata/114745?includeExtras=1&includeOnDeck=1&X-Plex-Token=...gYad
03-11 14:36:01.338  i: Fetching [method:GET] https://192.168.1.140:32400/media/subscriptions?X-Plex-Token=...gYad
03-11 14:36:01.347  i: Fetching [method:GET] https://192.168.1.140:32400/media/subscriptions/scheduled?X-Plex-Token=...gYad
03-11 14:36:01.385  i: [MediaSessionBehaviour] Updating metadata for video, thumb: true
03-11 14:36:01.436  i: Fetching [method:GET] https://192.168.1.140:32400/library/metadata/114745/children?excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto%2CVast%2CTopic&excludeFields=tagline%2Cfile&includeExternalMetadata=1&includeLibraryPlaylists=1&includeRecentChannels=1&includeStations=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...gYad
03-11 14:36:01.507  i: Fetching [method:GET] https://192.168.1.140:32400/library/metadata/114745/children?excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto%2CVast%2CTopic&excludeFields=tagline%2Cfile&includeExternalMetadata=1&includeLibraryPlaylists=1&includeRecentChannels=1&includeStations=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...gYad
03-11 14:36:01.508  i: Fetching [method:GET] https://192.168.1.140:32400/library/metadata/114745/children?excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto%2CVast%2CTopic&excludeFields=tagline%2Cfile&includeExternalMetadata=1&includeLibraryPlaylists=1&includeRecentChannels=1&includeStations=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...gYad
03-11 14:36:01.523  i: Fetching [method:GET] https://192.168.1.140:32400/library/metadata/114736?asyncAugmentMetadata=1&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto%2CVast%2CTopic&excludeFields=tagline%2Cfile&includeExternalMetadata=1&includeExtras=1&includeLibraryPlaylists=1&includeOnDeck=1&includePreferences=1&includeRecentChannels=1&includeStations=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...gYad
03-11 14:36:01.544  i: Fetching [method:GET] https://192.168.1.140:32400/library/metadata/114736?asyncAugmentMetadata=1&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto%2CVast%2CTopic&excludeFields=tagline%2Cfile&includeExternalMetadata=1&includeExtras=1&includeLibraryPlaylists=1&includeOnDeck=1&includePreferences=1&includeRecentChannels=1&includeStations=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...gYad
03-11 14:36:01.579  i: Fetching [method:GET] https://192.168.1.140:32400/library/metadata/114736?asyncAugmentMetadata=1&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto%2CVast%2CTopic&excludeFields=tagline%2Cfile&includeExternalMetadata=1&includeExtras=1&includeLibraryPlaylists=1&includeOnDeck=1&includePreferences=1&includeRecentChannels=1&includeStations=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...gYad
03-11 14:36:01.580  i: Fetching [method:GET] https://192.168.1.140:32400/library/metadata/114736/children?excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto%2CVast%2CTopic&excludeFields=tagline%2Cfile&includeExternalMetadata=1&includeLibraryPlaylists=1&includeRecentChannels=1&includeStations=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...gYad
03-11 14:36:01.599  i: Fetching [method:GET] https://192.168.1.140:32400/library/metadata/114736/children?excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto%2CVast%2CTopic&excludeFields=tagline%2Cfile&includeExternalMetadata=1&includeLibraryPlaylists=1&includeRecentChannels=1&includeStations=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...gYad
03-11 14:36:01.663  i: Fetching [method:GET] https://192.168.1.140:32400/library/metadata/114736/children?excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto%2CVast%2CTopic&excludeFields=tagline%2Cfile&includeExternalMetadata=1&includeLibraryPlaylists=1&includeRecentChannels=1&includeStations=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...gYad
03-11 14:36:01.679  i: [Preplay] Notifying listeners with status: SUCCESS
03-11 14:36:01.685  i: Fetching [method:GET] https://192.168.1.140:32400/hubs/metadata/114745/related?count=20&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto%2CVast%2CTopic&excludeFields=summary%2Ctagline%2Cfile&includeAugmentations=1&includeEmpty=1&includeExternalMetadata=1&includeLibraryPlaylists=1&includeMeta=1&includeRecentChannels=1&includeStations=1&includeTrailers=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...gYad
03-11 14:36:01.699  i: [Preplay] Notifying listeners with status: SUCCESS
03-11 14:36:01.716  i: Fetching [method:GET] https://192.168.1.140:32400/hubs/metadata/114745/related?count=20&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto%2CVast%2CTopic&excludeFields=summary%2Ctagline%2Cfile&includeAugmentations=1&includeEmpty=1&includeExternalMetadata=1&includeLibraryPlaylists=1&includeMeta=1&includeRecentChannels=1&includeStations=1&includeTrailers=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...gYad
03-11 14:36:01.727  i: [Preplay] Notifying listeners with status: SUCCESS
03-11 14:36:01.730  i: Fetching [method:GET] https://192.168.1.140:32400/hubs/metadata/114745/related?count=20&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto%2CVast%2CTopic&excludeFields=summary%2Ctagline%2Cfile&includeAugmentations=1&includeEmpty=1&includeExternalMetadata=1&includeLibraryPlaylists=1&includeMeta=1&includeRecentChannels=1&includeStations=1&includeTrailers=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...gYad
03-11 14:36:02.385  i: [LiveTuningBehaviour] LiveTunedInfo created. Tuned Item key is: /livetv/sessions/51df4b8f-8bcd-49aa-966a-4d1f925acdf9
03-11 14:36:02.387  i: [PlaybackManager] Preparing for Justice With Judge Mablean - Dawdling Driver Deliberation & Switched After Death
03-11 14:36:02.388  i: [DefaultPlaybackManager] Ignoring passthrough, since we've prompted previously.
03-11 14:36:02.400  i: [DefaultPlaybackManager] No codecs being downloaded.
03-11 14:36:02.405  i: [VideoAwakeBehaviour] Keep screen awake has been requested disabled for VideoAwakeBehaviour.
03-11 14:36:02.407  i: [Player][ExoPlayer] Using PlayQueueMediaSource
03-11 14:36:02.412  i: [MediaCodecVideoSyncRenderer] Setting allow dummy surface: true
03-11 14:36:02.415  i: [PlaybackTimeBehaviour] Time: 228571 IsStarted: false
03-11 14:36:02.417  i: [LiveScheduleBehaviour] Fetching timeline data...
03-11 14:36:02.419  i: [ExoPlayer][EventLogger] timeline [eventTime=236.52, mediaPos=0.00, window=0, periodCount=0, windowCount=0, reason=PLAYLIST_CHANGED
03-11 14:36:02.421  i: [ExoPlayer][EventLogger] ]
03-11 14:36:02.422  i: [Player][ExoPlayer] onTimelineChanged (Position: 228362 ms, Duration: 232031 ms)
03-11 14:36:02.423  i: [ExoPlayer][EventLogger] mediaItem [eventTime=236.52, mediaPos=0.00, window=0, reason=PLAYLIST_CHANGED]
03-11 14:36:02.425  i: [ExoPlayer][EventLogger] tracks [eventTime=236.52, mediaPos=0.00, window=0, []]
03-11 14:36:02.426  i: [ExoPlayer][EventLogger] state [eventTime=236.52, mediaPos=0.00, window=0, IDLE]
03-11 14:36:02.427  i: [ExoPlayer][EventLogger] playWhenReady [eventTime=236.52, mediaPos=0.00, window=0, true, USER_REQUEST]
03-11 14:36:02.429  i: Fetching [method:GET] https://192.168.1.140:32400/:/timeline?airingID=223175&audioStreamID=291674&duration=232031&guid=plex%3A%2F%2Fepisode%2F5fc6b9e38aba71002d848ffc&key=%2Flivetv%2Fsessions%2F51df4b8f-8bcd-49aa-966a-4d1f925acdf9&playbackTime=228571&playQueueItemID=7.1-1615491000000&ratingKey=122361&state=paused&time=228362&token=...gYad&X-Plex-Client-Identifier=c2ba770c8a492cb4-com-plexapp-android&X-Plex-Token=...gYad
03-11 14:36:02.430  i: [TrackSelectorHelper] Resetting track selection
03-11 14:36:02.431  i: [MediaSessionBehaviour] Updating metadata for video, thumb: true
03-11 14:36:02.433  i: [ExoPlayer][EventLogger] timeline [eventTime=236.53, mediaPos=0.00, window=0, periodCount=1, windowCount=1, reason=PLAYLIST_CHANGED
03-11 14:36:02.434  i: [ExoPlayer][EventLogger]   period [?]
03-11 14:36:02.486  i: [ExoPlayer][EventLogger]   window [?, false, true]
03-11 14:36:02.488  i: [ExoPlayer][EventLogger] ]
03-11 14:36:02.489  i: [Player][ExoPlayer] onTimelineChanged (Position: 228362 ms, Duration: 232031 ms)
03-11 14:36:02.490  i: [ExoPlayer][EventLogger] mediaItem [eventTime=236.53, mediaPos=0.00, window=0, reason=PLAYLIST_CHANGED]
03-11 14:36:02.491  i: [ExoPlayer][EventLogger] state [eventTime=236.53, mediaPos=0.00, window=0, BUFFERING]
03-11 14:36:02.497  i: [Player][Timeline] Error appears to be due to server termination: Recording failed. Please check your tuner or antenna.
03-11 14:36:02.499  i: [Player] Error reported: ServerTerminationError (Recording failed. Please check your tuner or antenna.)
03-11 14:36:02.500  i: [TranscodeSession] Stopping...
03-11 14:36:02.501  i: [Player][Timeline] Playback stopped (error: false)
03-11 14:36:02.504  w: [Player][Timeline] player position was negative. Position time will be reported as 0.
03-11 14:36:02.509  i: [PlaybackTimeBehaviour] Time: 228571 IsStarted: false
03-11 14:36:02.511  i: [FFmpegExtractor] Released.
03-11 14:36:02.518  i: [FFmpegExtractor] Interrupting extractor.
03-11 14:36:02.529  i: [FFmpeg] [INFO] [FFmpegExtractor] Reading whilst closed, exiting.
03-11 14:36:02.533  i: [EngineEventManager] onPlaybackStopped: Closed
03-11 14:36:02.545  i: [FFmpeg] [INFO] [FFmpegExtractor] Closing demuxer context.
03-11 14:36:02.551  i: [Player][Error] Displaying player error...
03-11 14:36:02.553  i: [DialogBehaviour] Showing dialog.
It’s not your imagination, it’s more noticeable with Plex Media Server content (not available yet) but time to start up has been greatly improved.
This happens when the tuner failed to switch channels, as playback now starts faster there might be an issue attempting to playback before it’s fully turned. Will have a look into this.
Will take a look at the other issue, that should of fixed in the build above. :thinking:
I also should have mentioned that the Error every time switching channels is not due to today’s release. It has been like this for a few stable releases. I’m not exactly sure which release it started on. I can try to run a few different releases to narrow down when it started.
I get this error too and you’re correct, it’s been a problem but usually if I try a second time it will play.
Thanks @jg121212 and @kegbeach, sounds like an unrelated issue but will take a look.
Thanks @sixones,
I did go back through some old versions and the most recent one I could find that didn’t crash when switching channels was 8.10.0.21911 from December 2020. Thats probably too far back to be able to do any source code comparisons as too much has probably changed.
Just need to find a way to sort out the buffering when watching a current recording from the beginning. Which still happens even with this build installed!
Do any of the beta releases address the guide search issue?
Excuse my ignorance, what guide search issue are you referring too?
@sixones Do you know if the issue with watching recordings currently in progress and the buffering happening is being looked at, or isn’t even on a timescale of being sorted?
The guide search issue is only Plex Web can you search for a programme and it shows up. If you use Plex for Android and search for a programme it will not show up. Even if you have a recording set and it’s in the EPG.
This is being looked into, thanks for reporting.
Do you have any more information on this? Will make sure it’s being looked into.
[quote]Do you have any more information on this? Will make sure it’s being looked into.
[/quote]
Here’s a link to the main issue:
Start Watching Recording in Progress from Beginning(Failing) - #950 by zetoune and there’s some videos others have uploaded to Youtube of the issue.
