Server Version#: 1.31.0.6654
Player Version#: 9.15.38159
Fire TV Stick 4k Max
Fire OS Version: 7.6.2.4
Fire TV Audio setting: Best Available
My AVR that the Fire is connected to supports all audio formats
Burn Subtitles: Automatic
Passthrough HDMI
Plex Refresh Rate Switching ON
Resolution Switching Off
Allow Insecure Always
H264 Max Level: 5.2 (Recommended)
When playing a file with EAC3 7.1 track, the video doesn’t play at all. Pause/Play doesn’t do anything. Scrobbling doesn’t do anything. The video is just a black screen. logs.txt (41.1 KB)
If I set Plex Refresh Rate Switching OFF, then playback just causes a crash:
02-17 12:18:26.155 e: [ExoPlayer][EventLogger] playerFailed [eventTime=3.74, mediaPos=0.00, window=0, period=0, errorCode=ERROR_CODE_AUDIO_TRACK_INIT_FAILED
com.google.android.exoplayer2.r: MediaCodecAudioRenderer error, index=3, format=Format(1, null, null, audio/eac3, eac3, 0, english, [-1, -1, -1.0], [8, 48000]), format_supported=YES
logs.txt (5.2 KB)
Then:
- Plex Refresh Rate Switching On
- Fire Surround Sound > DDP or DD
Makes no difference.
Then, I changed the settings again:
- Fire Surround Sound > PCM
This time the file plays back fine (Direct Play) but my AVR only receives stereo PCM.
Fire TV supports DDP 7.1 passthrough so this seems like a Plex issue.
