Fire Tv not showing all channels live DVR
Server Version#: 1.18.2.2058
My Live Tv Guide is only showing one channel on my fire tv, everything is up to date and it’s weird because two weeks ago it was working perfectly then all of a sudden moving to a different tv it isn’t . I have now updated it after a week of troubleshooting and it didn’t fix it. I run the server on ubuntu. It shows up fine on every other device apart from the fire tv. Any ideas or help? I can access the channels through on right now tab but it’s inconvienient and hard.
Same issue here. Have rebuilt EPG’s multiple times. Log out log in on clients etc etc. Still no joy. Guide works great on IOS and PC. Anyone else have these issues?
Sounds exactly the same, are you on fire tv or android tv?
Yes I have found the fix…
Installed a plex APK (latest version) from pureapk. All working well now. You will have to go to enable devolper apps in the settings on the TV. I placed an APK on to a USB stcik and insalled a file manager onto the TV and installed the app from the file manager. Make sure you uninstall the original Plex app in the first place.
For my fire stick I was having the same issues. So installed downloader app bowsed to pure APK and installed the APK. All working as it should in both instances.
