Firestick
Server Version#:4.69.1
Player Version#:About Screen only shows licenses but Firestick says Plex v 8.28.0.30077
When I start the app on my fire stick (TV), why do I have to scroll to the bottom of the Plex menu, click on “More”, then select my server, THEN scroll down to the library I want to view? The tv app used to open DIRECTLY to my server and that’s what I want back. Can this be done? I can only find instructions for possibly changing the opening screen on Plex web. This is silly to know scroll through options I’ve never used and probably never will use. . .
Thanks for any advice!
After you click on More, navigate to the desired library. Press the left side of the ring on the remote to move to the left. You should see 3 vertical dots. Select them. You’ll see an option to Pin the library to your home screen.
Once you’ve pinned the desired libraries, you can use the same process on the home screen to place them in the desired order.
This lets a user see only the desired libraries on the home screen and also arrange them in the desired order.
TY! I guess this got all reset with the last update. I completely forgot I had customized because it has been the same for so long. AND I would so much prefer to just click on my SERVER and add it to the sidebar instead of having to open each library and pin it. But as long as the customizations remain through updates I will be happy.
Thanks for the help.
