FireTV s t ick constantly buffering - used to work fine
I started using the Amazon FireTV stick lite back in October 2020 and things were great.
But In the last month or so (May 2021) all sorts of problems have cropped up.
I’ve tried updating the Plex app a few times, and just updated the server (ubuntu)
On some videos Plex is unusable. On the same FireStick, same video the VLC app plays fine through smb share.
I noticed this in the plex console while trying to play:
Jun 07, 2021 20:03:56.210 [0x7f3e10e64b38] Debug — Completed after connection close: [x.x.x.x:45348] 206 GET /library/parts/53884/1558825413/file.mp4?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=74944 (17 live) TLS 174ms 1343488 bytes (range: bytes=104902849-)
Jun 07, 2021 20:03:56.362 [0x7f3e10d12b38] Debug — Auth: authenticated user 1 as plexuser
Jun 07, 2021 20:03:56.362 [0x7f3e113cdb38] Debug — Request: [x.x.x.x:45352 (Allowed Network (Subnet))] GET /library/parts/53884/1558825413/file.mp4?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=74944 (17 live) TLS Signed-in Token (plexuser) (range: bytes=104907459-)
Jun 07, 2021 20:03:56.363 [0x7f3e113cdb38] Debug — Content-Length of /Movies/video.mp4is 6316870150 (of total: 6421777609).
Jun 07, 2021 20:03:56.382 [0x7f3e10d12b38] Debug — Failed to stream media, client probably disconnected after 1163264 bytes: 104 - Connection reset by peer
Jun 07, 2021 20:03:56.382 [0x7f3e10d12b38] Debug — Completed after connection close: [x.x.x.x:45350] 206 GET /library/parts/53884/1558825413/file.mp4?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=74944 (17 live) TLS 196ms 1163264 bytes (range: bytes=90820225-)
Jun 07, 2021 20:03:56.529 [0x7f3e10e64b38] Debug — Auth: authenticated user 1 as plexuser
Jun 07, 2021 20:03:56.530 [0x7f3e11424b38] Debug — Request: [x.x.x.x:45354 (Allowed Network (Subnet))] GET /library/parts/53884/1558825413/file.mp4?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=74944 (17 live) TLS Signed-in Token (plexuser) (range: bytes=90821223-)
Jun 07, 2021 20:03:56.531 [0x7f3e11424b38] Debug — Content-Length of /Movies/video.mp4is 6330956386 (of total: 6421777609).
Jun 07, 2021 20:03:56.547 [0x7f3e10d12b38] Debug — Failed to stream media, client probably disconnected after 1032192 bytes: 104 - Connection reset by peer
Jun 07, 2021 20:03:56.547 [0x7f3e10d12b38] Debug — Completed after connection close: [x.x.x.x:45352] 206 GET /library/parts/53884/1558825413/file.mp4?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=74944 (17 live) TLS 185ms 1032192 bytes (range: bytes=104907459-)
Server Version#: 1.23.2.4656
Player Version#:8.18.1.25719
Would you be able to fetch the client logs and I will take a look to see if it shows why it might be constantly buffering for you. Steps on gathering the log files are available here: Android, Android TV, Fire TV, Portal Logs | Plex Support
I sent the logs in a DM
