After the latest Plex version upload Fix Match is Gone. What happened??
Can you be clearer about the server and player versions you are using?
…your post this could get read after another version is released and then it no longer makes sense.
I am on server v1.20.3.3483 (QNAP) and I can see “fix match” on “Plex for Mac” v 1.21.0.
Ah. Makes sense.
1.20.3.3483-211702a9f
Plex Media Server
PC
Windows 6.1 (Build 7601)
Can you post a snap shot of what you see when you click on the 3 dots at the bottom-right of a film? …this is what I see:
You can’t Fix Match an episode, you must do that at the Show level.
I’ve always found it right where I took the picture. As you can prob see there is a blank box for a series in my screen pic. I always clicked as shown and Fix Match and Match appeared and I selected the correct option.
That’s still the episode. Click on the show’s name to go to the show overview page.
I can see it at that level but before this update I could see the Fix and Match from the three dots at any level. honest. Thx for your help.
