Server Version#: 4.57.4
Hello Guys and Gals. I have just added 7 new series to my server. Four of those matched just fine. One of them matched incorrectly and Two of them did not match at all. I try to use the match/fix match method but it is missing from the options (right corner/three vertical dots). Any ideas
This option should only be available on the show/series level. If you’re accessing the context menu from a hub like „recently added“ this could be pointing to a season or individual episodes.
You nailed it! I was doing it on the recently added category. Thanks for helping🙏
