Just upgraded to latest version, and now Fix Match isn’t giving me any choices. Ive got several incorrect Matches which need sorting, but I can’t get anything working.
Is anyone else having the same problem?
(Windows 10 server, Microsoft Edge and Internet Explorer browsers).
… and sometimes, no matter what you do, you’re just left scratching your head… for instance:
C.H.U.D. (1984)
comes up with
Sixteen Candles (1984)
C.H.U.D. (1984) doesn’t even appear in the list UNTIL you, in the Search Options, rename the Title to: CHUD and remove the year field.
Captain Horatio Hornblower R.N. (1951)
refuses to match anything, right or wrong and doesn’t appear in the list, UNTIL you rename the Title to: Captain Horatio Hornblower RN and erase the year… no problem then.
The BEST option is to name perfectly.
Eventually you’re going to need to know how to fiddle with Search Options, 'cause you WILL be fiddling with Search Options.
Note:
If you’re having a lot of trouble matching file names with dots between each word… Duh?
