Server Version#: 1.19.5.3112
Player Version#: 4.41.1
For some reason Match button does not show always:
I checked the database and everything is fine, naming convention of files is same for all my shows which do not have issues, season name - s01e01 - episode name.mkv:
You can’t fix match on a season, only the show as a whole. On the show page you will see the seasons posters below the show poster . on a season page you will see the episode of that season under the season poster. If you just added those episodes from that season the Recently Added hub on the home screen will show the season poster which goes to season page.
Click the title of the show to get to the show page.
this should also be Show Name - s01e01 - episode name
Ya that’s what I mean, show name not season name.
Thanks for showing me the right way to check for Match, however, nothing is found.
I had to specifically chose the agent, default TVDB would not be able to pull the information, which is a first. I used Movie Database instead:
Yeah the TVDB api has been weird ever since they made their site changes. You can use the TVDB series ID number in the title field.
