Fix Match search window
I just replaced an old server with a new Win11 Plex server built from scratch. There appears to be some pesky coding that happens when I go to fix a mis-match - it keeps trying to replace the incorrect match data back into the search fields. For instance: say it mis-matches to “Movie A” made in “2020”. I enter “Movie B” and clear “2020” from the date field (I don’t know the date of Movie B), but it seems to search for “Movie B” dated “2020” which doesn’t find Movie B because it doesn’t exist.
It shouldn’t do that. When I click on “Fix Match”, that should be a key that the existing match info is incorrect and it shouldn’t keep trying to use that data, but it does.
