They don’t use Plex apparently.
or read TVDB/TMDB.
an obvious shortcoming.
That’s why many/most/some of use FileBot.
or read TVDB/TMDB.
I’ll have to get on that…
Yup. For instance:
When you stick the brand new Family Guy Season 15 Uncensored DVD that Amazon sent (along with your 3 mo. supply of designer pygmy lion food) into the apparatus (MakeMKV for the first stage), you are met with this Title Field:
I’m not sure who that Title Field serves - but it ain’t any of us - and if we don’t deal with it RIGHT NOW it’s gonna be embedded into every single file off this disc and stink like a rotten bean/broccoli/boiled egg fart every time you turn around.
With the first field on the left activated, highlight the bogus Title Field on the right and hit delete, then hit enter:
Poof… Gone - for every item in the list on the left.
At least we don’t have to deal with that any more. <— I would then right click on the upmost field to the left and choose ‘Unselect All’. I can see which ones are episodes. I’ll go in and turn off VOB subs, turn on the UTF-8 subs, these discs so happily contain and away we go.
If I knew these episodes were correct, I could go in right now to each episode, open ‘File Name’ on the right and give each one a preliminary name like:
family guy s15e1.xxx - and so on - but I don’t know about these episodes until I get them out here where I can look at 'em.
I will do that when I identify them - and Filebot will bring it home.
DVD with SRT subs?!!!
Also:
Looney Tunes (1929) - VOB and Plain Text.
Ah, Closed Captions. Those are relatively rare on DVD.
Extremely so, but always a welcome find.
This is quite frustrating…
I don’t understand why Plex won’t let me force match a video to a particular ID - especially for documentaries.
I get it - auto matching is vastly improved by filtering results by movie / tv series per library. But I’m specifying the exact match criteria.
But if I specifically tell Plex that a particular file matches a particular imdb profile
By specifying “tt8254060” in the match
Example:
It’s in movies because it’s the only instance of this long-running straight-to-tv feature of longer documentaries.
Le sigh
Plex Movie won’t do Documentaries or TV Shows.
Name it this:
The Kingdom How Fungi Made Our World (2018)
Fix Match, Search Options, Agent drop down:
Select TMDB.
(the TMDB ID# trick doesn’t work all that well)
Got Docs?
Use TMDB.
Go there and find your Doc - name it that.
(or have Filebot do it for you in a fraction of a second)
Also, in future, for more stubborn items…
You can, Fix Match, and in Search Options, select from the Agent drop down Personal Media, then hand edit the item and make it anything you want. You already know where all the artwork and descriptions are.
Also for the item above - depending on how long you’ve been working on it under Plex’s watchful eye - you may want to Plex Dance that item for a complete Do-Over:
A new bundle with all the right stuff in it - is always welcome in the Plexiverse.
Nailed it! Thanks JuiceWSA
(I had wrongly interpreted that it wouldn’t allow a TV match in a Movie library (regardless of agent) but I guess as long as TMDB has a listing (any category) then the TMDB agent will match it)
Worked a charm - now I can go fix the last few stubborn items and that’ll be the whole library sorted
If you name it what TMDB calls it it’ll probably, at least, show up in a Fix Match.
You know what to do if it won’t cooperate.
Absolute champion - even works a charm for concerts (which I’d virtually given up on)
I’d set TMDB as default if I wasn’t so attached to iMDB ratings
I do so many Docs I need TMDB.
I get a few ratings, not many.
I think I’m getting RT ratings, if the setting actually does anything, but at this point it’s actually not clear where those % ratings come from - and they are few and far between.
