Instead of “Fix match,” it should be “Fix Where File Is” and “Fix the Description” - Fix Match is incomplete and poor wording.
A) Plex insists that THE EQUALIZER 2 is THE EQUALIZER (file) AND NO amount of “Fixing Match” does anything - even if it clearly brings up both files and I click on EQUALIZER 2. It will ONLY play EQUALIZER that’s NOT even in the same folder!
B) We now have a huge backlog of films with the same name but are spaced decades apart. I have PENELOPE, the Natalie Wood movie from 1966. There is also a Penelope movie from recently and it insists it’s the recent one. While the file plats correct (as I only have the 1966 movie), I cannot change the metadata, I click on and off the “lock” bar - sometimes it insists the data changes cannot be saved until I clear ALL THE WINDOWS but as soon as I close it changes my 1966 date of release back to the last movie (2000something). Why isn’t there an erase this info because t’s NOT correct button instead of a semi-locked state that refuses to accept or even offer we might have the older version of the film? Shouldn’t it ask or let us ask?
