Fix mismatch now gone?
Hello, some reason lately (within the past couple weeks) ive noticed the wrong info on one or two shows, mainly as theres issue where tvdb lists incorrect when imdb shows it correctly.
Normally i click “fix mismatch” or just “match” and tell it where to search etc.
However, this option is GONE! now i cant fix it at all?
All i have now are: refresh metadata, analyse, optimise, download, get info (no idea why i would download it off my own computer lol)
Fix Match is only available on the top level of a show, i.e. it is not available on the ‘season’ or ‘episode’ level.
Does that mean I now. Have to enter the show to. Change It?
I’m doing it on the tv programmes “page” which has all my. Shows listed as I usually click on the three dots on the programme picture and it showed there and scroll to check they all look matched
I did recently move server from laptop to my pc and then pelx had an Update. Am I in the wrong place? Movies work fine in the movies tab but the tv show tab it’s missing.
Am I now. To go to Each show page one by one?
Thanks for the quick reply
It has always been that way, AFAIR.
Please provide a screenshot of where you think something is missing. I am not sure where you are expecting to see the command.
